Anyone that has installed this seat on their '04 had a problem with the rear mounting tab not lining up with the rear bracket on the fender? It's too low near the fender and I need it bent up toward the seat more. There's a half inch gap between the rear of the seat and the fender, and if you want you can lift the seat right off at the back.
According to the Corbin website, " The tongue is made of a mild steel that will bend easily enough with an adjustable wrench clamped on it. Very little bend is needed in most cases, so be careful not to overdo it!" I beg to differ...the steel seems like spring steel, not mild. It won't bend, AND you can't get a friggin "adjustable" wrench on it, without shredding the leather covering.[:0]They didn't figure enough room for the adjustment of the tab to pan[/emoticons/emotion-6.gif!]
Has anyone come up with a fix for this? (without sending the seat back to Corbin 3000 miles away?)
Any hints would be appreciated!
Thanx
Thanx
