Front cylinder exhaust post
1.9K views 19 replies 11 participants last post by  repsol61
Had one of my exhaust post studs snap off flush. Trying to figure out best way to fix it.
#3 ·
The easy out bit snapped off also and the broken part is in the stud.
Well that makes it a little harder.
Some heat and penetrating oil might help get the piece of easy out removed.
Get a pic of out here for us. Any surface left for you to work with on the bolt?
Can you drill a hole in the top of the broken stud or has the easy out taken all the surface?
#4 ·
They make some star bits that i used. Get the right size and just put it in the hole you drilled and hit it with a hammer, it breaks up the easy out and it falls out. At least mine did.
#5 ·
spot weld to the stud with a mig welder turned up a little over what you would do a regular spot weld with , hit the stud ,dont worry the weld will not stick to the aluminum at all, then build it up and while its still hot grab it with some vise grips and it will probably just spin right out. btk572
#11 ·
in alot of cases with a mig welder and small nuts the weld will most of the time weld to the nut before you get a good weld to the stud, so i would say first try the weld to just the stud method and some small vise grips, heat is your friend here and all the heat in the stud will work the very best . btk572
#17 ·
Well been hammering and drilling and got some progress. 7/32 wide hole 3/8" deep. View attachment 64865
akwarrior79 ... some years ago i repaired my buddies outer stripped M8 stud with a thread insert.
At this point, based on your photo, what would work nicely is a drill jig that you can make from an exhaust flange or equal.
You can use the good stud to retain the jig that will guide your drill bit
gl
#14 ·
I believe this is the most-frozen stud I've seen at the front jug. Lucky you. But its the only way remaining to extract it so keep at it, go slow and give-up for the day if you are frustrated at any moment because its not worth a replacement cylinder.
#16 ·
Ouch . . . so with that front jug's exhaust port at an angle headed right at a frame upright you probably had to pull the jug to get machine shop work done? I'm more and more happy that I use a dab of nickle-based anti-seize on only the outer threads where those header nuts go. Hopefully I don't over-tighten (anti-seize makes things so slick during re-assembly its hard to know) but it seems a better alternative right now anyway. I've realized that this particular stud breaking can become a real nightmare and I didn't really appreciate how much of a nightmare until this particular thread.
But ak, don't get disgruntled, you can beat that sucker into submission!
#19 ·
i would clean it up and weld the dog shittt out of it then put a candle on it for a few seconds to lubricate the threads, and then grab it with vise grips, all the chipping, hammering, and pizzing around is going to spread the top of the stud if you havent already done that. it look to have a crack or split in the 2 oclock position coming from the 12 oclock position. the more you work it the more you over work the are and lessen the chances of a clean removal, btk572
