Status
Not open for further replies.
81 - 100 of 163 Posts
Discussion starter · #81 ·
Re: Popular Mods and Repairs
This line item will be added in next update:
Oil - Bolt (Valve)(F106): http://www.fumotousa.com/
I don't have experience with this valve yet, but will try on one of the bikes next oil change.
It is advertised as being only 1/2" longer than the plug. For the Warrior we would need 2.
Their Part# F106 is 14mm 1.50p and appears to come with a washer (but verify!).
AWESOME - I FOUND THE WARRIOR KNOWLEDGBASE GREAT WORK, got a LOT of reading to do now....
Save
Discussion starter · #87 ·
Discussion starter · #88 ·
The July update has been posted. Thanks to everyone who participated.
If you provided info for this update but its not included, just send me an email.
Next update will be posted around September 1st 2010.
Discussion starter · #90 · (Edited)
Sorry,
A link to WyomingWarrior's list, mentioned above, has been in the Popular Mods post for quite some time. It's found here:
PART 1: Technical Compilations
1. Model Year Differences: http://rswarrior.com/forums/t/16547.aspx
2. European Differences: http://rswarrior.com/forums/p/2815/46518.aspx#46518
3. Do It Yourself (DIY) Mods List: http://rswarrior.com/forums/t/129336.aspx <--
4. Fat Tire Group Buy 2007: http://rswarrior.com/forums/t/2227.aspx
5. Rear Tires 2007: http://rswarrior.com/forums/t/48415.aspx
6. Rear Tires 2008: http://rswarrior.com/forums/t/48781.aspx
7. Integrated Tail Lights: http://rswarrior.com/forums/t/48410.aspx
8. Integrated Tail Lights: http://rswarrior.com/forums/t/121392.aspx
9. Touring Seats: http://rswarrior.com/forums/t/48408.aspx
10. Post Your Exhaust Pictures: http://rswarrior.com/forums/t/114042.aspx
11. Post Your Grip Pictures: http://rswarrior.com/forums/t/115261.aspx
12. Handlebars and Cable Length: http://rswarrior.com/forums/t/115270.aspx
13. Oil Filters (verify): http://rswarrior.com/forums/t/48922.aspx
14. Brake System Part Numbers: http://rswarrior.com/forums/t/114111.aspx
15. Post Your Mirror Pictures: http://rswarrior.com/forums/t/120028.aspx
16. Downloads Page on RSW: http://rswarrior.com/files/folders/reference/default.aspx
17. Motorcycle Calculators: http://www.dansmc.com/mc_software.htm
18. CAD Drawing Software: http://www.3dexport.com/img14620.search.htm#topimg
Discussion starter · #92 · (Edited)
Alright! Thanks!
To those who have emailed me, thanks, and please hang in there. I sent both Darkstar and Carknee a PM to have this sticky re-stuck, but they seem overloaded right now and it might take awhile.
Here's the link to the knowledgebase: http://rswarrior.com/forums/t/115929.aspx
Discussion starter · #93 · (Edited)
October update posted.
Clarified ODO in Tach w/better post link.
Please help make this tool even better by suggesting topics. Click on 'Quick Reply' and provide the link you'd like included. If you have found a better conversation on a topic then please post the new link you are suggesting, plus the link you believe can be removed in trade (if any).
Discussion starter · #98 · (Edited)
I've added the stock rear spring dimensions to the knowledgebase, it will publish when the next update is posted, and reads as follows:
Stock Rear Spring: 782-pounds, 188mm free length, 172mm installed length, 58mm ID, 83mm OD.
By comparison, the 2010 Eibach catalog shows these springs:
Dimensions: Inch - - - - - - Dimensions: Metric
0700.225.1000 - - - - - - - 180-060-0175
0700 = 7" (178mm) - - - - -180 = 180mm
225 = 2.25" (57mm) - - - - -060 = 60mm
1000 = 1,000 pounds - - - - 0175 = 175N/m (~999 pounds)
These MIGHT BE the same spring. Just with 'rounded-off dimensions' due to the inch-to-metric conversion math.
But I don't know!
Does anyone have an 0700.225.1000Eibach spring loose, and can measure?
Status
You have insufficient privileges to reply here.
